Finished!!
Old Jun 2, 2002 | 08:20 PM
JR305's Avatar
Finished!!
I just finished my intake/cam/head/transmission swap and have been driving the car. I just have a few questions, how much base timing should I be running right now I am running 8 advance? The car will run fine before it gets warm, then it has a problem keeping a steady idle. If I let it idle it will die after 10 seconds or so.
I am running world heads, edelbrock preformer TBI intake, and a ZZ4 cam 208/221 .474/.510 112
Old Jun 2, 2002 | 11:01 PM
iroc22's Avatar
My car gets kinda wacko too when it's warm and sitting at stoplights. Bumping down the timing seems to help.
Of course I haven't done AFPR, Ultimate TBI mods or chip burning.
Old Jun 2, 2002 | 11:06 PM
TBI305Camaro's Avatar
when you get the bugs worked out let us know i was kinda wanting to do the same mods to my car.
Old Jun 3, 2002 | 09:07 AM
Brent's Avatar
Did you swap from an auto to manual trans? If so you need a manual trans prom. Thats part of the stalling problem.
The VSS needs to work properly also.
Old Jun 3, 2002 | 11:11 AM
JR305's Avatar
Yeah, I swaped from auto to manual. I also don't have the speed o hooked up right now i swaped from a 700r4 to a T56.
I think I also might have an ignition problem too, have not had time to really check it out though. When I am driving it will cut out real quick then return to normal. The tack will drop to zero, then return to its original reading.
Old Jun 3, 2002 | 01:57 PM
JR305's Avatar
Just to add to the ubove, when I swaped out transmissions I just connected two of the six wires that went to the auto shifter. The green and the purple wires.
It seems to cut out and go back on most often when I have been crusing for a while. Anyone have any ideas?
SRKLEGIN
Oct 29, 2015 06:38 PM
91 SrS
Oct 7, 2015 04:32 PM
loud91rs
Oct 5, 2015 10:05 PM
James Sutton
Sep 23, 2015 01:56 PM
Linson
Sep 21, 2015 01:08 PM
