timing advance with cam swap?
Old Jun 9, 2002 | 06:00 PM
RallySport92RS's Avatar
I just got the LT1 cam yesterday, before I install it I was wondering if I need to bump up the timing or fuel pressure or anything like that? and Will valve springs and a new timing chain be all I need for the swap?
1992 RS, 305(l03)
Old Jun 9, 2002 | 06:04 PM
NJ SPEEDER's Avatar
you are gonna want to advance the timing a bit with the new cam and more fuel pressure is a definite. you will need to have intake gaskets and a damper puller/ installer tool to get teh job done. you will also need a compressed air source to hodl the valves up while you change the springs.
later
tim
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
