what kind of filter for a TBI?
Old Jun 16, 2002 | 03:41 PM
streetrunner's Avatar
im getting ready to do the "ultimate" mods to my TB. And i want to switch to the K and N 3" non drop base air cleaner. Where is the cheapest and what part number do i need to get. Also where can i find a Throttle position sensor? to make the CPU think its at full throttle at 60%. What psi would the motor run best at with those modifications? Stock everythign else. (heads headers intake ect.)
Old Jun 16, 2002 | 05:20 PM
NJ SPEEDER's Avatar
just go to your local parts store. they usually have cheap open element filters there. don't worry about a k&n filter, a plain old paper filter will work just fine. most places have cheap chrome filters for under $20
later
tim
Old Jun 16, 2002 | 06:15 PM
Slade1's Avatar
We did a test the other day to see if K&N filters are worth it among other things. One thing that was noted is that K&N filters when are like having no filter at all. Produced same results on torque/HP curve. Another thing was that common air filters vs the K&N, the K&N had a steeper curve than the paper filter, it means that the engine got up faster almost nearly 15% faster at all RPM for the whole curve. Is it worth it? Hell ya I think. As for some other certain cash eating mods (we had 1 guy feel really bad at his $300 lost on a certain mod which gained <1HP and lost 2ft/lb of torque over the stock item).
My recommendation is get a K&N but any old chrome non drop filter with it will be fine.
Old Jun 17, 2002 | 07:31 AM
if i already have a 3" filter from K and N can i use that with another air cleaner assembly?
Old Jun 17, 2002 | 07:39 AM
what kind of non-drop base opwe element 3" have you used? I just want to make sure i get one that works and will fit my TBI.
Old Jun 17, 2002 | 07:50 AM
NTChrist's Avatar
Any non-drop 5 1/8" housing will work.
Our TB's have the same mounting diameter as common carbs do.
In other words, I'd be amazed if you managed to buy the wrong size.
I bought mine from Summit. It came with a 14X3 reusable element.
Old Jun 17, 2002 | 10:47 AM
deadtrend1's Avatar
Summit Part #: KNN-60-1263. I was an idiot and bought it just because it had the K&N Logo and it was flat base. The non drop Sparca one or whatever its called at the part store didnt sit correctly and I couldn't stand it. I haven't noticed any H/P gains from the paper to K&N, but I feel better knowing I have one.
Old Jun 17, 2002 | 12:00 PM
thanks guys. im looking at the K and N unit that is raised a bit to clear the distributor fropm jegs 13/16" to be exact and its 14" by 3". thanks again.
92camaroJoe
Jul 29, 2023 07:57 PM
italiano67
Dec 11, 2016 09:21 AM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
