fuel pressure dropping
Old Jun 18, 2002 | 02:13 AM
AUTOGON350's Avatar
Car: 93 S10 blazer
for some reason my fuel pressure drops the longer the car runs.
Im thinking its the spring in the regulator heating up or something.
when I first start the car its at 17psi and after about 15 minutes it goes to around 12psi
perhaps it is a very moody leak.
any ideas?
Old Jun 18, 2002 | 05:38 AM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
Sounds like a pump problem. The regulator is such a simple piece, there's very little to go wrong in it. It could, conceivably, leak through the diaphram but that wouldn't change from start up. It would leak all the time.
Old Jun 19, 2002 | 09:00 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: fuel pressure dropping
any ideas?
If your fuel pressure gauge is a liquid filled and exposed to
the engine heat. . . It is very possible the gauge is reading
incorrectly. On a cold engine and not running wire the pump
to run all the time (red wire at relay to B+).
Then use a hair dryer on the gauge.
Under these circumstances I've seen them drop like a rock.
RBob.
Old Jun 19, 2002 | 09:19 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
I didnt think it was heat because I have been running without a hood (cowl hood delivery got screwed up).
I will try the hairdryer thats a good idea.
thanks.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
