can someone look at these aldl readings?
Old Jun 20, 2002 | 10:48 AM
carter89RS's Avatar
I finished building the cable the other day and went for a drive. Can anyone look at the log files and tell me whats going on?
File Type: txt
Old Jun 20, 2002 | 01:29 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
I cleaned up the data a bit and put it in Excel format.
Some of it looks weird...
After you download it, unzip it.
File Type: zip
Old Jun 20, 2002 | 06:54 PM
carter89RS's Avatar
what looks weird?
Old Jun 20, 2002 | 09:46 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
MAP looks a tid bit high...But that all depends on your engine combo.
Old Jun 20, 2002 | 10:03 PM
carter89RS's Avatar
engine is bone stock except for a 14x3 open element.
Old Jun 22, 2002 | 10:46 AM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Hmm...it looks to me like the MAP is a little high. What kinda of problems are you experiencing?
Old Jun 22, 2002 | 01:53 PM
carter89RS's Avatar
rough idle and the oil pressure is dropping a little everyday. it bounces around with the rpm's near the redline (i added some to make sure it didnt drop past the redline).
also occasional blue smoke at startup (i know this is probably my valve seals)
Bubbajones_ya
Jul 6, 2024 08:32 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
greenyone
Sep 8, 2015 08:41 PM
Gunsbee
Sep 7, 2015 07:10 PM
