LT1 cam, last time
Old Jun 24, 2002 | 06:03 PM
RallySport92RS's Avatar
LT1 cam, last time
Ok i have the LT! cam and its going in tuesday. what should i buy with it, the timing chain, valve springs, ????? and where do you recommend getting them from?
thanks a lot! Jesse
Old Jun 24, 2002 | 06:44 PM
maroon91rs's Avatar
Car: 91 Camaro RS
Engine: L03 305 baby!!!
Transmission: stock 700r4
i recommend doing a search.i think everyone else might agree with me.not trying to be an ***,its just that this is another one of those subjects that has been beat to death.good luck with the swap!
Old Jun 24, 2002 | 07:33 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I really wish there was a tech article on this swap, but I can understand why there isn't. Just off the top of my head, from previous posts: lifters and your timing chain are a must. I believe the stock springs will work and can handle the lift-it's up to you whether or not you think they can be reused due to milage, etc. I think Sonar said he used quite a bit of the high temp RTV as well. Check under his name when you search, he updated the board daily when doing his swap. Best of luck from a fellow thirdgen-er who hopes to be able to do the same swap. Let us know how it turns out and what kinda results you get after she's properly tuned.
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
TheExaminer
Aug 19, 2015 10:07 PM
Thirim
Aug 9, 2015 06:19 PM
