LT1 Cam installation
Old Jul 1, 2002 | 10:37 PM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Hey guys,
I finally got my LT1 cam in the mail the other day. I've been paying attention to everyones conversations about the cam so I'm pretty up to date on the whole thing. My question is can someone go over the cam installation so I know I don't forget anything. I'm going to install an Edelbrock TBI manifold with it too. I plan on replacing the timing chain and valve springs with this mod. I plan on getting new heads within a year too.
Thanks for your help.
Old Jul 2, 2002 | 12:07 AM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
The sort of overview you're looking for has been typed out a bunch of times here recently, just go through a search and you'll find plenty of info. Most of the work is self-explanatory and not too bad if you're semi-careful and have some help every once in a while.
The valve springs/seals took me a lot longer than I'd expected (almost a day), so be prepared for that. Also, I think if I'd known about the oil pan gasket issue w.r.t. replacing the timing chain cover, I may have planned to lift the engine and drop the pan and basically do it right (on the other hand, the hi-temp RTV I gooped along that area is holding perfectly thus far...).
Good luck!
Old Jul 4, 2002 | 11:41 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
click here
Old Jul 7, 2002 | 01:57 AM
racereddy20's Avatar
good luck. got mine done last month. it was a pain. Didnt take too long but it was a pain. I had a good spout of cussing and swearing that day, and the next (started late, after 5:00pm)
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
anesthes
Mar 10, 2016 10:35 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
