what is limp mode
Old Jul 5, 2002 | 05:46 AM
92RSQ8's Avatar
what is limp mode
could someone please explain what limp mode is to me?
i saw it in another post and was wondering if someone could explain it to me
Old Jul 5, 2002 | 11:07 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: what is limp mode
There are actually two failure modes for a GM ecm.
But, folks tend to lump them together. Anyway,
1. Limp Home Mode,
Is when there is a processor failure, and the ecm just runs on the redundant fuel devise, and the ignition advance in the ignition module. It's designed to just get you home. In case of a huge failure, there might not be a check engine light.
2. Fail Soft Mode,
Is when there is/are sensor failures, and the ecm uses some default values instead of the bad values, and lets you drive home with the check engine light on.
Old Jul 5, 2002 | 05:41 PM
Slade1's Avatar
I never realized there were 2 different modes. I just recalled the time my dad screwed up his TA.. well some mechanic did and while driving went into this crappy mode spitting out rich exhaust and barely moving. GM tech explained to us that it was a limp mode and since his entire sensor system shorted, the ECM backed off into it. I had no clue though that the other mode existed if the ECM itself went out.
Rocket-Doc
Nov 14, 2015 02:08 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
327IROC85
Sep 23, 2015 12:11 AM
david068513
Sep 18, 2015 10:36 AM
ULTM8Z
Sep 16, 2015 09:15 AM
