idling
Old Jul 5, 2002 | 11:11 PM
lanespice's Avatar
idling
cant figure out why my engine idles up and down over and over til my car warms up? i'm geting a 44 on my ses.
305 tbi 92 camaro
Old Jul 8, 2002 | 06:05 PM
lanespice's Avatar
cant figure this one out can ya???
Old Jul 8, 2002 | 06:09 PM
Tas's Avatar
Tas
idling up and down is normal. Check the codes in the tech section.
Old Jul 8, 2002 | 08:55 PM
forsaken_one's Avatar
Im not sure about your code but the surging of the idle sorta sounds like a malfunctioning EGR system. Like the EGR valve is getting stuck open and inhibiting a smooth idle. does it surge and then drop really low, where it almost cuts off?
Old Jul 8, 2002 | 09:53 PM
lanespice's Avatar
yes it idles down to the point to where it cuts off... what do i have to do to remedy the problem?i would very much appreciate the help
Old Jul 8, 2002 | 10:31 PM
Slade1's Avatar
The egr isn't commanded to function till consistently high rpm. 2000+ usually. Sounds more like you have a vacuum leak to me. Check the IAC for leaks.
Old Jul 9, 2002 | 08:35 AM
That is true slade, but sometimes the components malfunction and the valve is stuck open at idle, letting the gasses enter with the air and fuel. My egr was at one time stuck open with a big chunk of carbon. If you have a vacuum pump you can test the EGR system and you can also test the engines vacuum, like slade said. It may also cause part of your your problem.
Old Jul 9, 2002 | 11:01 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Mine used to surge at idle until warm.
It was a vacuum leak at the base of the throttle body.
-Rich-
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
