With these mods, what would you mod next?
Old Jul 6, 2002 | 12:29 PM
RallySport92RS's Avatar
Hey everyone, I have a 92 RS with the 305 tbi.
My mods so far are 3.73's with posi, k&N airfilter, full 3 inch exhaust, and an LT1 cam with new springs, lifters timing chain, etc. With $350 canadian, what would you mod next? intake? chip?
subframe connectors? or anything else? Thanks in advance for any replies!
Old Jul 6, 2002 | 12:43 PM
iroc22's Avatar
Intake manifold. Get a nice single plane intake with a TBI adaptor.
Old Jul 6, 2002 | 02:37 PM
Tas's Avatar
Tas
7547 or 7525 weiand intakes and learn chip buring and tuning.
Old Jul 6, 2002 | 03:13 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
If you have a nice car and want to keep the body straight I would get the subframe connectors.
Old Jul 6, 2002 | 03:33 PM
I think I will keep saving and do both the intake and the SFC at the same time.
On a different topic though, I just bumped ip my fuel pressure and now when I let off the gas the car takes forever to slow down, is this just too much fuel pressure or maybe the timing needs adjusting?
Old Jul 7, 2002 | 12:53 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i dont think you need to worry about a LO3 twisting the frame
Old Aug 25, 2002 | 06:28 PM
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
True because there is no frame to twist. If he puts one in then the LO3 wont twist it. My car started to bend at the window corners and now I have lumps there. It sucks.
Old Aug 25, 2002 | 07:04 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Any time you go up/down a driveway, or in/out of a parking lot at an angle (like most of us do to keep from scraping) there's body twist.
Any time you take a corner/turn at a somewhat high speed, there's body twist.
Any time you accelerate (even in a 2.8 V6) there's body twist.
Any time you go into a turn while braking, there's body twist.
Any time you hit a pot hole with just one side of the car, there's body twist.
Any time my 230lb. *** gets in my car, there's body twist.
Need I continue? I'm starting to sound like Jeff Foxworthy with the "you might be a *******" skit.
AJ
Old Aug 25, 2002 | 07:37 PM
Slade1's Avatar
I have a stock lo3 and my b-pillars are going... got the standard stress cracks at the top, but on the passenger side there's a stress bend forming...
I'd do headers for that car, you got the exhaust to flow better, but the headers really hurt. I'm doing that next on my car along with a new even higher performance cat.
If you have t-tops or convertible, disregard that and get the sfc's...
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
