LT1 cam and distributor gear?
Old Jul 20, 2002 | 03:28 AM
DuffMan's Avatar
Car: '99 Cobra
Engine: 4.6 DOHC 32V
Transmission: T-45
Axle/Gears: 4.10
If I am correct, the LO3 had flat tappet cams stock correct? If so, I need a complete hydraulic roller kit when I buy and LT1 right?
Also, do I need a different gear for my distributor? I heard the bronze piece isnt really reliable after a while, so would it just be easier to buy a MSD distributor or something?
What is the exact part from Holley for the 670 cfm TBI that fits on our cars? I cant find it on Summit. Thanks a lot!
Eric
Old Jul 20, 2002 | 04:09 AM
Tas's Avatar
Tas
truck L03 is flat tappet, car L03 is roller.
Old Jul 20, 2002 | 10:26 AM
Slade1's Avatar
Get the one rated for 5.0 L/305... that will tide you over quite nicely...
Old Jul 20, 2002 | 05:00 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
And if you're using a roller cam you need to use a bronze gear. Much better to wipe out a $25 bronze gear then a $200 cam.
Old Jul 20, 2002 | 05:39 PM
Brent's Avatar
Not true. Aftermarket and stock hydraulic roller cams require the melonized distributor gear not bronze.
Old Jul 20, 2002 | 11:21 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
If you're using a LO3 (like Tas said) from a Camaro/Firebird, then you can use the same distibutor that you have now. Those engines came with roller cams from the factory. An LT1 cam is a roller cam from the factory. No problem there.
Here's the link to Jeg's for the TBI.
http://www.jegs.com/cgi-bin/ncommerc...22&prmenbr=361
It's for a GM truck, and IIRC, the TPS plug is a little different than ours (I'm not 100% sure about that. JPrevost is the one to ask). But other than that, it works fine (from what others have said).
AJ
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
junkcltr
Aug 2, 2019 11:12 PM
midge54
Jan 29, 2017 07:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
