Oil sender/fuel switch location?
Old Jul 21, 2002 | 03:33 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Have a look at the photo-sorry about the quality of it! Is this where the oil pressure sender/fuel switch goes on the 305 LO3?
Thanks.
Andy.
Attached Thumbnails Oil sender/fuel switch location?-oil-sender-unit.jpg
Old Jul 21, 2002 | 10:31 PM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
yup...thats the oil pressure sender switch and thats where it goes. some advice... before u asselbme the rest of the motor...try getting that plug out without stripping it. if it doesnt come... heat it up and take it out. also, check the pass. side of the block on the bottom in the middle... thats where the knock sensor goes. take that out too.... i needed to disassemble my whole motor to heat those up cuz i didnt wann amess anything up.
Old Jul 21, 2002 | 11:31 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
i think it goes in the hole without the plug. Im pretty sure of that.
Old Jul 22, 2002 | 03:17 AM
Car: 91 camaro rs
Thanks Camaroguy71. Good advice too!
dimented24x7. Don't put it in that hole since that goes straight through to the firewall area!
Andy.
Old Jul 22, 2002 | 11:59 AM
Car: 88 Camaro SC
Engine: SFI'd 350
lol... guess im wrong... nEver bothered to look to hard b/c i never hooked mine up anyhow. the ecm turns the pump on by reference pulse.
Old Jul 22, 2002 | 04:12 PM
Car: 91 camaro rs
Hi dimented24x7.
Thanks for your input to my problem above anyway!
Did you do the TBi swap onto the 350 yourself? If you did, how did it go? What bits were difficult?
Andy.
Old Jul 22, 2002 | 04:46 PM
Car: 88 Camaro SC
Engine: SFI'd 350
i did mine myself over a three day period. Overall it was pretty straight forward. I used an older motor so i had to use a carb intake and adapter which required me to resize my tv and throttle cables as well as bend my fuel lines to get them to run to the tbi w/o interfiering with anything else. I had to use brass fittings in my sensors to get them to fit into the older heads but that was no biggie. Pretty much everyhting else went together as planned. The only part that really irritated me was trying to get teh last two bolts in when i reconnected my engine to the trans. After fumbling with one for like 5 mins i dropped it down the y-pipe and had to go and get a similar grade and size bolt to replace it. The place where i ran into alot of probs was on start up with the ammount of heat generated by the new motor. Lots of friction b/c of low clearences. I had to break my initial 30 min breakin run into two 15 minute runs because the engine was starting to overheat. Also had rediculously high oil pressure too. The only prob i had after that was a slipped dissy. that caused the timing to go way retarded and tripped the ses light. So far after around 350 miles and a month or so its been good.
Old Jul 31, 2002 | 08:56 AM
Car: 91 camaro rs
Hi dimented24x7.
I need your advice.
Believe it or not, I am having great difficulty in locating these brass fittings in the UK. Where did you get yours from? What size were they? Have you got any photos?
We can get BSP threaded adaptors, but not NPT here.
It looks as if I will have to get them from your country!
Andy.
Old Aug 1, 2002 | 01:13 PM
Car: 88 Camaro SC
Engine: SFI'd 350
i got them from pep boys. They where 3/8 to 1/2 brass adapters. R&B, the company that has motormite and dorman as their brandnames makes them. This is their web page . Look under brass fittings. Your local autoparts store might stock their stuff. Just about every store has em over here but then again this isnt the uk. See if the store cant speacial order the fittings. I suppose as a last resort one of us over here could buy them and mail 'em to ya.
Old Aug 1, 2002 | 01:46 PM
Car: 91 camaro rs
Thank you!
This might just have solved my problem!
That web site is amazing! I think I will be using them more than once!!
Thanks again.
Andy.
89GTAOz
May 16, 2020 09:31 AM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
355sbcTPI
Aug 19, 2015 04:38 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
