TBI and LT4 HOT cam
Car: 92 RS Convertable
Engine: RAMJET 350
Transmission: G-FORCE T-5
TBI and LT4 HOT cam
I am currently putting together a vortec headed 9.3:1 compression 350 to replace the 200K mile TBI 305 in my 92 RS 5 speed convertableI was told that the LT4 hot cam was to big for TBI even with a chip and to go with the L31 vortec cam. I have an L98 cam. has anyone tried the hot cam?
also does any one have the specs for:
L98 cam?
L31 vortec cam?
LT1 cam?
LT4 hot cam?
L98 cam?
L31 vortec cam?
LT1 cam?
LT4 hot cam?
If you are planning on burning your own proms then the LT4 Hot Cam is not to big. It will require a bunch of work to get it to idle and drive nicely.
If you are not willing to do prom burning then you best stick with the LT1/L98 size cams. The L31 is smaller then all the ones you mention.
A quick search will reveal the each of those cam's specs.
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
You also need to be careful with the lift on the cam L31 heads max at .480" lift with out machine work. LT4 Hot cam is .525"
junkcltr
Aug 2, 2019 11:12 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
