I've got the BLM Count between 109 and 128
Car: C1500
After my mods I built the cable for the laptop to use winaldl. I've been struggling trying to find out where my power is after my mods. I went to the track and I only picked up 1.5mph from stock.
I finally got some power out of my car yesterday after I advanced the timing a large amount.
I checked the BLM count today and they are between 109 and 128, that isn't on the stock fuel pressure. Do you think I can get the BLM's tuned in more? I'm running stock 305 injectors right now, I have been thinking of going to 350 injectors so I can run a lower pressure.
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
128 is dead even, which is good 109 is on the rich side but still with in the ECM's pararmeters to adjust the fuel(it should be the same on TBI ECM's) so i wouldn't worry about it, try turning down the FP a pound or 2 and see if that helps..
Car: C1500
I got a longer sample tonight coming home from work. I'm running very rich under 2000rpm After that it seems to be around 125-130. After it warms up, I'm getting 108 at idle and if I'm out of gear and rev it up I only come out at 1500rpm. I guess I do need to turn it down a touch.
