Code 54 on a TBI?
Old Jul 31, 2002 | 08:47 PM
5.0L1992RS's Avatar
Code 54 on a TBI?
I am getting a code 54. Howver it is not all of the time, it is every 1 in 20 starts. Then I turn my car off and turn it back on and the light is off. I have the haynes manual, but it says the M/C soleniod is bad, but i don't have a M/C soleniod. So I searched around and found that it is the fuel pump relay circuit on a TPI engine, but is it the same on the TBI? If so, how can I go about fixing this?
Thanks for any and all help,
Kevin
Old Aug 1, 2002 | 11:09 PM
5.0L1992RS's Avatar
any help would be appreciated.
Old Aug 12, 2002 | 04:27 PM
Buck268's Avatar
I am having the same problem. Extremely hard starting - if it starts. Pull a code 54. Chiltons doesnt even list that code!!! Any help would be greatly appreciated!!!
Also - Does anyone know anything about a "Fuel Pump/Oil Pressure Switch" Its on the same cuircut as the fuel Pump.... Maybe that could cause a problem???
Old Aug 12, 2002 | 08:29 PM
5.0L1992RS's Avatar
I just got pissed that no one was helping me, so I went to a local shop and got them to replace the fuel pump, filter, and relay. It works great now.
Old Aug 12, 2002 | 11:14 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Code 54 is for the fuel pump relay and oil pressure switch. They are on the same circuit from what I can tell. I had a problem with starting a while back and it was because of a faulty oil pressure switch. I guess it could have prevented the entire circuit from functioning properly. So I changed the switch, because it was bad, and the fuel pump relay, just to make sure and the problem was fixed.
92firebirdguy
Sep 1, 2016 07:53 AM
BumpaD82
Feb 26, 2016 02:57 PM
Glowsock
Sep 11, 2015 11:09 PM
92rsvortec350
Sep 10, 2015 10:54 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
