89rs vs 91rs
Old Aug 4, 2002 | 07:10 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
89rs vs 91rs
i have a 89rs and a 91rs. the 89 is a auto and the other a stick. when i first start the 89, the idle is at 1500 then after a while drops to 500 when it is warm. my 91 starts and is at 1000. but doesn't drop. is this because of the chip. if i swap chips will the idle be switched from cars. or will a auto chip not work in a stick.
Old Aug 4, 2002 | 11:39 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
Sorry but the chip wont work, because the one is an auto and the other is a stick. Plus the year model is different too what you need to do is just order one from HYPERTECH or have some one burn a custom one the one from hyper tech is about 125.00 plus you will need to buy a fan switch that will make your fan kick on at and eailer temp.
Old Aug 5, 2002 | 04:53 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Man, don't waste your money on a hypertech chip- I bought the thermomaster and it did nothing but eat more gas. The reason the idle is different is because the characteristics between a standard and auto idle are different. Even if you did buy the hypertech chip for your 5-speed, the idle characteristics would be the same, as the only thing they change in those chips is the air/fuel ratio and a little timing.
Cubman
Members Camaros
Sep 20, 2015 02:05 PM
TKD89RS
Nov 17, 2001 03:48 PM
89RSProject
Aftermarket Product Review
Aug 3, 2001 08:05 PM
89RSProject
Feb 8, 2001 10:33 PM
DEEPSOUTH90RS
Oct 30, 2000 10:28 AM
