Idle is high after driving hard
Old Aug 7, 2002 | 11:29 PM
sslee's Avatar
If I drive my car hard it idles high like 1300. I can kill it and crank it back up and it idles normal. What is the deal ?? Can someone give me ideas..
Old Aug 8, 2002 | 09:13 PM
sslee's Avatar
ok I put a new iac on and coolant temp sensor and it still does it. Also it won't idle up in the mornings..
can someone help..
Old Aug 11, 2002 | 06:50 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I had this probelm also, The only way to fix it is to burn a prom. I decreased my Idle gain from 5 to 3, and set my max IAC counts to 60 from 145. Now the motor is unable to Idle above 1000 rpm.
Old Aug 13, 2002 | 12:02 AM
sslee's Avatar
I shouldn't have to burn a prom if the engine is stock. Stock 350 and tbi ecm and harness from donor vehicle.
Old Aug 13, 2002 | 01:10 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
may I suggest that a small vaccum leak might cause this.
Old Aug 13, 2002 | 02:35 PM
RSCamaroGuy92's Avatar
Car: 92 Camaro RS
Engine: 355 94 p/u motor
Transmission: 700R4 With TCI kit
Hmm, sounds like Oxygen
could be a faulty Oxygen Sensor. That would explain why it wont idle up when cold. The 02 sensor is what the computer reads when it is cold after it warms up, and the 02 sensor gets a certain reading, the computer runs the car off of the water temp.
So when you start cold, the 02 sensor is probably giving the computer the wrong signal to idle off of the water temp sensor, which would cause a "weak" idle.
If its not the 02 sensore, get a new chip, maybe the ECM is going haywire.
Azrael91966669
25
Jun 20, 2017 04:04 AM
db057
Aug 22, 2015 08:17 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
squiggy2
Aug 9, 2015 09:30 PM
