Emissions-legal intake?
Old Aug 8, 2002 | 03:40 AM
DuffMan's Avatar
Car: '99 Cobra
Engine: 4.6 DOHC 32V
Transmission: T-45
Axle/Gears: 4.10
I am cursed (and blessed in some ways) to live in California, where smog runs rampant as do tree-huggers. Therefore I must pass emissions and I am not sure if the Weiand intake manifold will pass. I have read they are better than Edelbrock, but if they dont pass, I cant use it. Also, where can I find info on the AFR heads, and any suggestions with a cam with those heads? LT1? LT4?
THanks in advance!
Old Aug 8, 2002 | 11:36 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
For the info on afr heads: http://www.airflowresearch.com/
But honestly unless you're building a nice 327+ ci engine you wont need a head that good. For most of our applications the GM Vortec heads or the World Castings SR Torquers are the way to go. I went with the Vortecs, and GM makes a 50-state legal (with erg, obviously) vortec manifold that looks basically exactly like the Performer RPM that Im gonna be running. I dont have the pn, but if you search you can find it
Old Aug 9, 2002 | 08:20 PM
AdmiralNahohkta's Avatar
Car: GTO
Engine: GM 350HO, 4.6 Overhead cam, 413 Wed
Here it is: part#12496821, also you need a Vortec gasket, part #12529094. But it's not cheep, figure $380
The GM Performance TBI to Vortec intake relocates the egr to the front of the intake, a brass reducer is needed to fit the temp. sensor, and a plug for the coolant bybass. It's a good intake and seems to flow better than my Performer.
Old Aug 10, 2002 | 02:35 PM
iroc22's Avatar
Pn# 8000 Weiand Intake is legal for use in the state of California.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
