Plenty of motor, not enough throttle body
Subscribe
Aug 23, 2002 | 12:09 AM
My 350HO swap is at the 1,500 mile mark. I'm still experementing with injector sizes and throttle bodies. Question: Can any amount of tweaking to TBI properly feed my motor? No, I wont switch to a carb, I really want to keep my TBI.
GM Performance 350HO w/ 9.1 compression; cast aluminum pistons; Stock Vortec heads; flat tappet cam with .435/.460, duration 212/222 @.050", LDA of 112.5; for the rest see sig.
Reply 0
Aug 23, 2002 | 12:21 AM
Your Holley 670 should be more than enough to supply fuel to your setup. JPrevost is running a very similar setup and he's trapping at 104 or 106 I believe. My *** needs to get a 2" tbi but Im flat broke.
You would really benefit from a chip which you seem to have addresed in the sig lol
Reply 0
Aug 23, 2002 | 10:37 PM
If you pull less than 1.5 inches of Hg at WOT than you have enough TB or a crappy intake. 3 PSI or less of exhaust pressure at WOT is another good thing to have.
Reply 0
Subscribe
