Keeps blowing a fuse
Old Aug 24, 2002 | 12:54 PM
Dex's Avatar
Dex
Its the fuse next to the battery 88 camaro TBI I did a search and its either the fuel pump fuse or ecm fuse.
but I went to leave and the car died started checking fuses and the fuse next to the battery was dead. Put new fuse in blows it.
with the negative cable diconnected I have power on the positve and negative side of the fuse. also with the negative cable disconnected if you touch it the the body and check it with the test light it has power??? but with the negative cable connected I only have power the the positive side and not the negative side of the fuse?HELP
also checked and cleaned the negative cable
I also just got done cleaning the underbody before I left
I made it a mile down the road talked to my brother shut it off went to leave and made it ten feet and died
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
90formulaVortec
Sep 3, 2015 09:26 AM
