lo5, goodwrench, or L98
Car: 91 Firebird
Wow, well congrats. Hope that it all actually holds out! You can't deny that there is a definite risk to running 380 ft. lbs or torque thru the stock tranny. That is just common sense. For every one person I know who has been "ok" I know 10 that have dropped many many parts that can't hold up. All I am saying is that if money is a factor, it might not be a good idea.
And what I meant by saying there are LO5 parts available in other cars is that they are readily available used. Meaning you could get them for much cheaper to make the combo work. For example a used ecm or chip from a junk yard Caprice, $35. Custom chip from Ed wright to make a 330 hp engine work correctly, $350. That was my point, obviously all Chevy parts are more or less the same. Besides, in any of his posts did he ask about the GMPP engines? I think he is leaning towards the L05, so go with it. Nice flame though for no particular reason. I can't stand guys like you who flame because they want to. Did I say something to pi*s you off? I don't think so. But congrats on your 13 second car.
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Originally posted by kdrolt
1. 1989 Caprice (brick body) 9C1 (police) LO5 350, first year for TBI. 190 fwhp and 290 ftlbs. This engine was not available in civilian Chevys until 1993 and even then it was detuned (using LO3 cam). Same specs for 1989-1990. The LO5 replaced the carburated roller lifter 350 (LG4?), which had 180 hp and 285 ftlbs IMS.
2. 1991 Caprice 9C1 (police) LO5 350, first year for whale body. Exhaust was revised so the engine was rated at 195 fwhp and 295 ftlbs. Civilian 180 hp version of the LO5 offered on Buick Roadmaster, Olds Custom Cruiser and Caddy Fleetwood... but not in the Caprice civilian model (they got the LO3 305).
In 93, the Brougham disappeared along with the FWD Fleetwood leaving the DeVille (4.9L/FWD until Northstar), with the remaining Caddy RWD being the (new) Fleetwood, a D-Body. It used an L05 for its debut in 93, but was rated at 185hp most likely due to the electric cooling fan(s).
4. ????-1995 GM truck (Tahoe, 'burban, not sure about C/K pickups) got a 210 hp version of the LO5. I don't know what cam they got, but they probably got a better breathing exhaust and that's where the power came from. The truck LO5s would have been better off with the milder LO3 cam, but I haven't ever checked what they actually got.
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Originally posted by dmair5_0
Wow, well congrats. Hope that it all actually holds out! Nice flame though for no particular reason. I can't stand guys like you who flame because they want to. Did I say something to pi*s you off? I don't think so. But congrats on your 13 second car.
As for custom chips, etc, You'll notice in my sig that I'm runing my 400 CID engine off of my stock, origional 305 chip and ECM. It runs very well. I'm sure it could run even better, but I'm pleased with the performance, fuel economy (24 mpg) and drivability I've achieved w/o a "$350" chip. I'm telling you and the original poster what CAN be done.
Car: 1995
Engine: 5.7
thanks guys, i know that i could get the 330HO but i was trying to keep the cost down. thats y i was leaning towards the LO5. This enigine is a straight bolt on right. its just like a bigger brother to the LO3. so its identical to drop in. im goin to put the LT1 cam in and later on some heads. what heads should i get ? how much power can the LO5 handle?
Car: 2002 Z28
Im sure the difference between the regular L05 and the 9C1 is the injector flow rate and possibly the cam. So just get the L05 add the LT1 cam, Edelbrock TBI intake, and get some 350 injectors (you should be able to find the 350 cop car injector part number on this website) and you shouldnt have to worry about whether or not it is the 9C1 replacement.
BTW you dont get a warrenty with the lo5 if you put it in a fbody...according to SDPC2000 the warrenty is voided if its put in something besides what its intended for.
Im probably getting the lo5 or the pc1 model...I NEED a motor now and right now my money situation is tight...just started a new job and i have school so i need something.
How much HP would a lo5 with lt1 cam, edelbrock TBI intake, and exhaust put out?
Car: 2002 Z28
im hoping when i put my L05 in with an LT1 cam, Performer TBI, and my existing Edelbrock headers, and Hooker cat back to get at least 250-275 HP
Amazing!
You guys are going round and round! I say call Recon and have them build that engine to your spec. Not the CRATE Recon, but the HP Recon engine line. Those engines are built by one ASE tech with what you want in it. The price is determined by what you actually want done, AND...
You get a 3 year/36,000 mile warranty.
I say look into it.
Why not get what you want in the first place? That's what I did.
LOL even so I got too much of a cam at first. My story is a long tale of hit-and-miss trial and error.
Now with all we know, you can get that engine you want built for you. My engine is a pre-86 2-piece 4 bolt mains, internally balanced.
I say get what you want and modify it, but look at the end result and price you pay.
Up to you.
Yes you will pay more for the HP Recon motor than a "crate", but not as much as you would if you had to take that "crate" apart and do all those things you suggest.
Footnote....
I got to talk a little to the tech that was building my engine... He was laughing as I ordered the gear drive... Ironically, he was nearly finished and was about to put the double roller in. He told me I'd get rid of the gear drive after a while. He was right.
I should know better.
http://www.reconengines.com/hp.html
Please read that page.
I say look into it.
Up to you.
Footnote....
Car: 1995
Engine: 5.7
true it would be better to start with something you want. but money wise im goin to have to get the LO5. i already have a LT1 cam. so later on heads will be goin on it.
I would rather get a performance crate or build a motor to my specs...just depends on my money situation I work part time at Advance and go to school so money is tight..
Oh and Im not getting a new motor I found my problem.
If your going to get a lo5 www.paceparts.com has the 9C1 lo5 with the lt1 bottom end and 9.6:1 compression. Has a l98 cam which is worlds better than a lo5 cam. Heads still suck but for 1500$ that would be a good solid start.
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
thats what i said...it has a l98 cam. Im sure the lt1 cam is better than a l98 cam but id rather have a lo5 with a l98 cam instead of the lo3 cams some of them got. i just pulled my lo3 cam...lt1 cam is going in soon as it gets here.
Assuming those features are correct, yes. They said that my engine that i got from some other dealership is the same as the one they sell. My last post was a direct quote, and there weren't any uncertainties in the message.
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
Car: 88 Firebird
Engine: 350 LO5 TBI
Transmission: 700R4 Vette Servo/Shift
I believe I have a LO5 also from an 88 truck. What do you mean by LT1 bottom end? And is it possible that my LO5 can have a LO3 cam in it. Mine just doesnt seem to have 220 hp. Its hard to believe Ill even experience a huge difference once I put in a 350 chip. (ive got a 305 chip in there now which is probably slowin it down).
Also, Im confused as to why some people are saying an LO5 is only good for 250hp. Last I checked you could get some L31 Vortec Heads, ZZ4 intake (or the edelbrock that fits), 454 TBI w/injectors and an LT1,ZZ4, or LT4 hotcam and be looking at over 350hp. Drop in a 383 stroker kit and itll be good for 420+. Ya youll need stall kits and rear end but the engine isnt nessecarily "limited" to 250hp.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I dont know what the exact specs are but the 88 most likely has a flat tappet cam in it. In short it sucks.
The 250 HP bit is due to the heads. Theyre crap. Without the heads and cam its no longer an L05, but rather a 350 shortblock thats good to around 5000 rpm or so. The parts you put on it will determine its power output.
Car: 88 Firebird
Engine: 350 LO5 TBI
If I have a LO5 am I pretty much guranteed to have a flat tappet cam and those swirl heads? Just curious becuase Im figuring out how much of my 305 could be remaining in my new 350.
Car: Badass 1991 Firebird
Engine: Screamin' 305 TBI
Axle/Gears: 2.73, 3.42's waiting to go in!
Ok, I've been looking at L98's and L05's, and the 9C1 cop engine, and I'm wondering if the Pace engine is the cop engine:
Details
12513151 - 92-93 B, D (L05) (Exc 9CI) vin code 7
MSRP $1,838.00
When a part listing says "Exc ____" doesn't that mean, "except this part," or, "not this part" as in it is NOT the 9C1 they are selling? I suppose I could look up the specs of both motors, cop vs. noncop motor, but if someone knows, please clarify.
Also wondering why I'm not reading about more L98 TBI's. Is it that folks go for the whole TPI setup as opposed to just using the motor? I want to buy/build up a 350 at some point, so I'm looking at options. 305 still runs great though, and quick, it's almost ridiculous for a 13 yr old car. Thanks.
Details
MSRP $1,838.00
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Originally posted by Poncho Villa
.... I'm wondering if the Pace engine is the cop engine:
Details
Details
There were no L98 TBI engines. The 9C1 LO5 got swirl port heads designed for fast burn in a heavy car application; the L98s were installed in much lighter cars (F, Y) and used different better-flowing heads. Most TPI owners would feel that removing the TPI for replacement by TBI would be a step backwards, so you aren't likely to read about them.... even though the TPI has it's share of problem areas. HTH.
Quote:
There were no L98 TBI engines. The 9C1 LO5 got swirl port heads designed for fast burn in a heavy car application; the L98s were installed in much lighter cars (F, Y) and used different better-flowing heads. Most TPI owners would feel that removing the TPI for replacement by TBI would be a step backwards, so you aren't likely to read about them.... even though the TPI has it's share of problem areas. HTH. [/B][/QUOTE]
Thanks for clarifying which engine Pace is selling--does anyone sell the cop engine or do you have to go to the junkyard?
As for my question about L98's, I was wondering if there are TBI owners who swap in the L98 for use with their existing TBI setup. I know the L98 is a TPI engine, I was just wondering if the L98 would be a good choice for a 305 TBI replacement motor, and if so, where to find one.
I want a smog legal 350 to go with my existing TBI and ECM, however, I want the strongest motor possible. The L05 doesn't make much more power than I already have, so I was thinking an L98 with a cam and other mods might be a better choice. I'd go full TPI but I don't want to have to change the fuel pump, harness, etc. (still might do it though).
Also, I have seen crate 350's on ebay, billed as Replacement TBI engines that are rated at 300+ hp, and I'm wondering if I'd pass CA smog with something like that, or a HO crate motor from Summit. Any ideas?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
[/B]
[/B]
Car: White KSwisses
Engine: 5.3L Gen III
Car: 1990 Firebird
Engine: LS3
here is my two pennies
ok I have a L05 but I didn't spend anywhere near $1,800. anyway what I did is got one from a junkyard (I think I spent about $700 or so) and planned on putting a few grand into it. I know I need new heads (those swirlports really do kill performance) exaust, cam and a few other things then I'll be happy with it (for now
anyway to the original poster: my suggestion is get a junkyard 350 for as cheap as you can find it and then put a grand or three into getting it to be excactly like you want it.
). anyway to the original poster: my suggestion is get a junkyard 350 for as cheap as you can find it and then put a grand or three into getting it to be excactly like you want it.
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Originally posted by cali92RS
Theres a problem with that. Here in Cali, you cant swap in a 350 with a TBI and have it smog legal. You gotta have what was available in the car at the time. So if u want to stay smog legal and a 350, u need to go the TPI route, or super ram
Car: White KSwisses
Originally posted by Cadillac
There goes my dream to install an LT1 one day.
In the case of a 350 TBI, it would be considered a truck engine and it would not be legal even if it had the corresponding smog equipment.
If u hit up the SoCal boards, there are people there that would be able to help u out a lot better than me.
Green Light On LT1, LS1
Thanks for the info on 350 TBI--have heard you can get away with it because on visual inspection, all SBC engines look the same, unless smog tech checks the block numbers (?) Was thinking a 350 TBI would be easier than a 350 TPI transplant, but I guess not if you can't smog it. Not sure about that though---I thought there were some Cali guys with LO5's, the Caprice 350. I will check the CA boards.
I read up a lot on LS1, LT1 swaps, and yes as mentioned above you can put in any motor, same year or newer, as long as smog stuff is there. Plus I've heard of lots of Jags with Chevy motors passing smog, but yeah you have to get a sticker from the referee.
Car: '86 Iroc, '87 Iroc Vert
Engine: 350 TPI, 305 TPI
Transmission: T5 in both
Axle/Gears: 3.73, 3.45 both LSD's
Guys, great thread. I have this L05 Engine in my RS. It has been changed over to TPI. I have to say that if you are buying the 12513151 350 L05 engine your not getting the L98 cam. Unless somebody has a build sheet or engine parts list that says otherwise, your getting the junk TBI cam. I personally don't believe what some guy over the phone says or thinks he knows. If he can't fax you a copy of the parts list, you can't take his work for it. Like it was mentioned, there were three different cam-med engines for this motor. If you were GM which would you be producing?? Besides, most of these engines are made in Mexico!!!
Thanks for the info, Z4U.
Question for TKD89RS who started this thread, I see you are in California, are you planning to stay smog legal? I know there is a bit of room for going beyond stock, but just how much I don't know. Also, I see you are already running a non-stock motor?
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
Unless of course you have a buddy at the test site.
Second, it is legal to swap engines if they come out of the same year or NEWER car--NOT trucks because trucks have different smog laws attached to them. So dropping an L05 from a truck into your car would not legally work. Also, you must swap all the smog garbage from the donor car to yours. Here is a web site that explains it all pretty well on how to go about the swap.
http://www.jagsthatrun.com/Pages/Che..._V-8_Smog.html
Anyway, just wanted to lay that out their for those who use their cars as daily drivers and have to pass emissions testing like I do.
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
Originally posted by ir0cz
I dunno if that's true w/ SDPC, but when i called Pace and said "i need a replacement engine for my camaro....they recomended the 9C1...and i DID get a warranty.
Car: 91 camaro rs blue with black stripe
Engine: 5.0 in car 5.7 in garage
Re: lo5, goodwrench, or L98
im glad u posted all i want 2do is burn a little rubber i aint goin 2 nobodys race i dont carew about time slips just tyin 2 impress d wife. i want about 265 hpout of lo5 that i got running complete 4 3hun
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
i think the L05 has allot of low end torque but lacks high revving power. the L05 is very similar to the engine that i swapped into my 89 RS. it is bored out .040 over and has an edlebrock cam, which probably helps a little
