Does the TBI and TPI f-bodys use the same fuel pumps??
Old Aug 29, 2002 | 11:52 AM
TBI89Formula's Avatar
I just bought a Granatelli Universal fuel pump that is supposedly for TBI,TPI,LT1 and LS1. I already installed it and as my previous post states, I am having problems with performance. Is this "universal" pump not acceptable for my TBI????
Old Aug 29, 2002 | 12:17 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Does the TBI and TPI f-bodys use the same fuel pumps??
Answer to first question: no. TBI & TPI use different pumps.
Check your fuel pressure at idle. A high pressure/flow pump can overwhelm the TBI regulator. This will result in too high fuel pressure.
RBob.
Old Aug 29, 2002 | 12:20 PM
Slade1's Avatar
TBI 15 PSI
TPI 55 PSI
CARB 6 PSI
You can get away with the TPI pump if you install an aftermarket fuel pressure regulator.
Old Aug 30, 2002 | 10:34 PM
Lionsden's Avatar
I'm running a TPI pump on my TBI car. The TPI pump is a common upgrade on a Crossfire car. The fuel pressure should be checked and adjusted if needed after the upgrade. The oem tbi fuel regulator compensates for the difference just fine.
Old Aug 31, 2002 | 08:04 AM
Slade1's Avatar
I wasn't sure if the oem regulator was up to the task, that's good to know.
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
