454 Throttle Body on a 305?
Old Sep 5, 2002 | 07:33 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
will a stock 454 Throttle body fit on a 91 Camaro with a TBI 305 that has a stock intake manifold
Old Sep 5, 2002 | 10:42 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
technically yes. actually nope. the stock intake has smaller bores then the 454 TB
Old Sep 13, 2002 | 08:27 PM
PhilM's Avatar
Car: Accepting applications...
Get yourself a spare manifold (junkyard or swap meet) and have the bores opened to 2". A decent machine shop should do it. Then you can bolt it on, may have to splice a few wires if the new tbi doesn't have the same tps and iac hookups
but be forewarned if you have a stock engine, this will not do a thing but flood it. it will run fine until you romp on it, at which point the 305 will drown in exxon and you won't go anywhere.
been there, done that.
Old Sep 13, 2002 | 08:37 PM
iroc22's Avatar
You gotta watch though that the factory TBI intake has water jackets running around the plenum. It's actually kinda difficult to open up the 1 11/16" bores to 2" without hitting a water jacket. A better route would be a 4bbl manifold with a TBI to carb adaptor.
Old Sep 16, 2002 | 04:27 PM
PhilM's Avatar
good point. i got lucky with both of mine.
Old Sep 16, 2002 | 05:55 PM
iroc22's Avatar
Oh yeah you can get lucky and miss the water jackets but it's difficult to do.
jhawkeye
May 25, 2022 06:33 PM
Fast355
Dec 2, 2016 06:33 PM
mdtoren
Aug 23, 2015 12:52 PM
justin57
Aug 20, 2015 07:05 PM
mdtoren
Aug 16, 2015 05:45 PM
