This Fuel problem is continuing!!!!! Need your help!! This is Rediculous!
Old Sep 8, 2002 | 09:54 AM
JucinGTA's Avatar
K well heres the sinario, my car bogged out after 3 grand big time, almost like it was gonna die, so I thought it was the fuel pump but ended up being I had the Top of the Airlid off and it was sucking the Fire retardent Material down and getting No Air!!
Well I stuck a Inline in there from my buddy, he told me to put it on this way and it would start, we kept trying and trying and trying!! Well I took it off and found out he told me to put in on the wrong way, so it was pumping to the tank So I switched it, the car ran fine, but when its cold it would barely even go without flooding and once warmed up would have some acceleration, but you could see it was getting way too much fuel. I know took the inline off and the orginal pump still works but I try to start the car and it will run for like a sec then die out, then I crank it for like 5 to 10 secs, then it will run for a sec and die out!! What do you think is going on?????
Old Sep 8, 2002 | 01:15 PM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
Just a wild guess, clogged cat?
Old Sep 8, 2002 | 04:57 PM
JucinGTA's Avatar
No cat.
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
