Tbi?
Old Sep 11, 2002 | 09:02 PM
EternalCamaro's Avatar
Tbi?
Do i have to replace anything else or do anything else to the car in sig if i replace the stock TBI unit with the Holley 670 cfm 2 Barrel TBI?
And what gains do you think i would get from his upgrade?
Old Sep 12, 2002 | 12:15 AM
iroc22's Avatar
You don't have to replace anything for the 670 unit. Holley supplies a gasket that makes the bigger TBI adapt to the smaller intake manifold. I would get a carb intake and make you're own 4bbl to TBI adaptor plate.
Old Sep 12, 2002 | 05:02 PM
wh0di's Avatar
I dont think you'd need a 670 until you have a bigger demand for air. Change heads/cam/intake then you'll need it
Old Sep 13, 2002 | 07:32 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Just curious, but does the Holley TBI come with injectors?
Old Sep 13, 2002 | 06:25 PM
iroc22's Avatar
Yeah it does come with injectors. The injectors they were installing on them awhile back were of terrible quality and they were planning on changing manufacturers. Don't know if they have done that yet. Might want to phone the tech line to see.
Old Sep 13, 2002 | 10:26 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Holley did change the injectors. I purchased my 670 TBI about 8 months ago. It came with GM Delphi injectors. The only problem I have had with the 57pph injectors is that they are a little to much for my set up. My fuel pressure is as low as I can adjust it, and I still run rich. I think the 502-4 comes with 50pph injectors, which may have been a better choice. However, I think proper prom tuning should do the trick, so if I ever feel brave enough to start tuning my own proms, my problem will probably be fixed.
Old Sep 20, 2002 | 02:17 AM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
I know how you feel. I need to learn to burn my own chips too. but im afraid that i will spend all the money for the stuff to do it and then wont be able to figure out how to ues it.
I GUESS I NEED TO JUST GET THE ***** AND DO IT
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
