Injectors not squirting during startup...
Old Sep 16, 2002 | 01:07 AM
allmotorta's Avatar
What would cause the injectors to not squirt while I'm cranking the engine over? If I pour gas in to "prime" it, it fires right up and the injectors start squirting. This is for my friend's TBI car. We can't figure it out If I don't prime it, it doesn't start obviously. Any ideas?
Old Sep 16, 2002 | 07:56 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Either the fuel pump isn't running or the VATS system is disabling the fuel pump if the key is not making the proper contacts in the steering column.
Old Sep 16, 2002 | 08:56 AM
Slade1's Avatar
Fuel pump relay is busted? Try replacing that...
Old Sep 16, 2002 | 01:04 PM
allmotorta's Avatar
The relay is good and the fuel pump is working. I pulled off the fuel filter and turned the key to "acc" and fuel shot outta the line. The fuel pump seems to be working good.
Old Sep 16, 2002 | 01:08 PM
Most likely VATS problem then.
Old Sep 17, 2002 | 01:02 AM
allmotorta's Avatar
We fixed it today. I noticed the dome light went out so I replaced the fuse for it. After I replaced the fuse the car started right up. Who would guess the courtesy light fuse would have anything to do with firing the injectors during startup? It was cool to have an easy fix for once tho
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
