Will a 454 tbi support a 14.1 at 96
Old Sep 16, 2002 | 11:37 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
I have a 84 monte that thinks it's a camaro so I hope you guys don't mind me mingling with you. So far my best run has been a 14.15 at 96.7 with a traction limited 1.97 60' time. Just can't stomp it off the line yet with the street tires. I have a 454 tbi and still need to put together the rest of the system. My car weighs 3600 pounds ready to go down the track so my best estimates put it at around 290-300 hp at the flywheel. From what I have seen in theory it should suport my engine but i was woundering if any one has done it before, also are there any problems i'm going to run into with this swap. I vaguely remember hearing somthing about the speed sensor but I have been out of the loop for a while. Thanks for your help!
:hail:
Old Sep 17, 2002 | 02:15 PM
NJ SPEEDER's Avatar
it will easily support it. i ran that kind of mph on a stock bore tb with ultimate mods, i am sure the bigger tb can handle it eeasily.
later
tim
Mongoose462ci
Sep 16, 2015 11:46 PM
CAMAROBEAV
European Region
Sep 12, 2015 10:04 AM
Glowsock
Sep 11, 2015 11:09 PM
