Holley 300-66 manifold, Anyone using it
Old Sep 22, 2002 | 09:05 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Guys, any of you out there using the Holley 300-66 manifold out there. I am interested in hearing your feedback on it in terms of performance and any issues in terms of problems with installation of it.
What do you guys think about me putting it on my L03 which is fairly stock (really just headers and other small stuff) and has a cam to come? Good choice, or not?
Old Sep 22, 2002 | 01:29 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I always take **** for saying this lol but Ill say it again.
With stock heads/cam you really dont need a better intake manifold and larger tbi. I'd save your money and get gears if you dont already have them.
But the manifold is solid. My friend greg runs it and he likes it , also has the 670 tbi. Didnt really help him out when he had stock heads/cam, but now he has ported 187s and the lt1 cam, it gets movin pretty good.
Old Sep 22, 2002 | 05:54 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Thanks for the input even if you take **** for it!
The cam is over the winter, so hopefully once the summer comes things will be ready to go (new intake/cam)
Anyways thanks again for the input
Old Sep 29, 2002 | 12:48 AM
therealalkybird's Avatar
I have the intake and the 670cfm on my bucket and they work pretty well on the built 350 in there just one problem, there is little to no chance of putting the EGR back in place without a throttle body spacer. But besides that it is a nice setup.
Old Sep 29, 2002 | 09:51 AM
Snowdog 91 Formula's Avatar
Yes you definitely need a spacer... about 5/8" at least if you are to use your EGR valve.
Old Oct 8, 2002 | 07:30 PM
MericanMuscle's Avatar
Using the spacer will you have enough hood clearance on a stock hood.. and would you have to use the spacer if you use the egr from a late 70s truck or something like that?
Old Oct 8, 2002 | 11:44 PM
You will need the spacer if you are going to use the EGR valve.
No getting around that.
I'm sure you can get away with a drop base element or a lower height air cleaner... say 2.5 inch.
Worth it.
Old Oct 9, 2002 | 10:38 AM
For the spacer should get one that was meant for the 7.4 since i will be running the 300-66 with the holley 670 tbi or the one the one that is for the 4.3 5.0 5.7 with the adaptor plate for the 670 tbi. this is from the jegs catalog. Also will the fuel lines give me any trouble??
Old Oct 9, 2002 | 10:44 AM
I had mine made custom for me, I have no clue about the ones from the magazines. Just be sure it's for the 2" bore and not the 1 13/16" bore.
Edit: I meant 1 11/16"
Old Oct 28, 2002 | 09:45 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
With the HLY 300-49 it says it is for Aluminum Heads.....will this work with my 89 stock L03 heads (cast)
Old Oct 29, 2002 | 08:57 AM
Difference between the 300-49 and the 300-66 is the angle of the two center bolts on the intake manifold.
The 300-49 would not be a direct bolt-on and the 300-66 will.
Old Oct 29, 2002 | 05:14 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Thanks...I am assuming it will fit under the stock hood, provided I am not running a 3" air cleaner
cowansauto
Apr 3, 2025 12:51 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
sreZ28
Oct 22, 2015 08:21 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
