My injectors are not firing
Old Sep 24, 2002 | 07:18 AM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
I swaped the entire drivetrain from my 92 RS into my 87 camaro that came with a LG4 originally. I used the engine harness and computer from the 92 and the dash harness from the 87. I have spark, and fuel is flowing, but it is going straight through the throttle body and back to the tank. My injectors aren't firing at all. So I think my problem my have to do with the fact that my RS had that VATS system? What can I do to fix that problem, or do yu think it could be something else? I can't remove the dash harness, VATS module or column from the RS, I need that for my other setup.
Old Sep 24, 2002 | 09:12 PM
Berlinetta's Avatar
A lot of people around here can disable the vats system for you. Just gotta find someone to do it for you.
Old Sep 25, 2002 | 07:18 AM
Car: 1992 Camaro
Engine: 350 miniram
I have a friend who is going to help me out with a chip that will eliminate the VATS feature, but that only solves half my problem.
My problem now is that the injectors each have there own fuse and because I am using a 87 dash harness from a car that had a carb. setup, there are no fuses in that block for my injectors. I need to know how the injector circuit works, can somebody shed some light on that for me? Anybody know how I should wire this up?
Old Sep 25, 2002 | 11:34 PM
FWP's Avatar
FWP
From what I understand so far (I'm still learning), 12V is applied to one side of the injector coils when the ignition is in run and start. The ECM then sinks to ground the other side of the injector coils in a timing pulse pattern, depending on ECM sensed fuel requirements. I'm adding TBI to a '77 motor in my old Blazer, and I plan on running a fused 12V run signal from the fusebox, directly to one side of the injectors. HTH
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
sahlomonic
Sep 20, 2015 07:15 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
