pic of tb, what do you think
Old Sep 27, 2002 | 01:14 AM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
this took me about an hour to do what do you think
Old Sep 27, 2002 | 01:15 AM
Car: 89 Camaro RS
Engine: 355 TBI
here is another
Old Sep 27, 2002 | 07:37 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Looks good to me.
Old Sep 27, 2002 | 08:08 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
needs more radiusing on the front lips, round em off, make it so there is no edge, dont go too deep. otherwise, looks great. what tool did you use? air grinder/polisher, or dremel?
Old Sep 27, 2002 | 09:22 AM
BillD91RS's Avatar
Before Picture
Do you have a before picture to post beside it. I would like to do the Ultimage TBI mods but not sure what to do. I have read the articles many times but still can't picture it in my head.
Bill
Old Sep 27, 2002 | 01:48 PM
Car: 89 Camaro RS
Engine: 355 TBI
no i dont have a before pic, I used a dremel cut off disc to cut the ridges off then i took a sanding block with some sandpaper and sanded it down and then i took a air wire brush and polish it up
Old Feb 16, 2003 | 07:58 PM
Car: 89 Camaro RS
Engine: 355 TBI
back to the top
Old Feb 16, 2003 | 08:12 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I used an air powered die grinder for the big cuts....and a dremel to finish it off.
Old Feb 17, 2003 | 06:37 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Camaro89RS355,
You took off all of the air filter supports. The open element will slide around on the throttle body now. I suppose you could tighten the wing nut down, but other than that, nothing's stopping it.
Old Feb 17, 2003 | 08:50 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Who are you talking to? V8Astro or Camaro89rs?
Old Feb 17, 2003 | 09:07 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Could somebody take a picture of the grinder they used or the item number if it was a dremel bit and what rpm was it at.
THANKS
Old Feb 18, 2003 | 10:01 AM
snflupigus's Avatar
the aircleaner doesnt slide around without those supports. - its on the center stud, then its tight, you dont have to worry bout it slidding around. at all.
spend the money and get the highspeed carbide cutting wheel. looks like a table saw blade on a stick. it wont dull at all or gum up. use that to cut it down. then round everything with a carbide drum, or sandpaper one works too. finish with lighter sandpaper drum, then hand polish.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TexasFormula
Sep 30, 2015 06:36 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
