intake manifold questions
Old Sep 29, 2002 | 02:13 PM
jcjohnston78's Avatar
a couple of days ago i found several leaks comming from between the engine and the manifold and the tbi and the manifold.
since i have to remove those parts anyways i was thinking about replacing the manifold with an emission legal carb manifold with an adapter or spacer for the tbi....any ideas or suggestions on products are the best for my camaro 305tbi.....part #s or links to where i can look at the product would be helpful.
for all my info on my car just look below.
thanx
Old Sep 29, 2002 | 02:18 PM
TBI305Camaro's Avatar
With most carb manifolds you will have to switch some stuff around. There is some fab work that must be done...the edelbrock TBI manifold is a direct replacement tho
ASE doc
Alternative Port EFI Intakes
Jan 12, 2020 11:35 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
