fuel presure reading help!!
Old Oct 16, 2002 | 10:36 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
i just made my fuel presure regulator adjustible and i was wondering how do i check to see if it is burning right can the o2 sensor setup for the quadrajet in tech articles work ar should i pull the plugs and check for color also ive heard that the back for plugs burn different should i pull the back plugs or front plugs thanks alot guys
Old Oct 17, 2002 | 08:34 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
It can work. Its just not near as accurate as the WINALDL setup that can give you a lot more than just 02 voltages.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
