A few questions about milling my heads..
Old Oct 27, 2002 | 01:26 AM
beamar's Avatar
I want to get more compression out of my car. So I was going to mill my heads. I just bought a set of heads from a 96 350, They are not lt1 heads they are standard centerbolt heads, they have springs and new valves in them, they have about 5k on them since the springs, hot tank, and valve job. I want to pull the valves, port the **** out of the heads, and have them cleaned and milled. I'm just worried if I mill them the valves with hit??? Are the stock pistons fly notched??? How much can I mill the heads without the worry of them hitting the pistons. It has new springs that can handle up to .530 lift. The cam I'm using has .4545 and should be around .490 with 1.6's. I'd still be using the stock lenght pushrods, right?
Sorry, my other motor is a OHC...
Brian
Old Oct 27, 2002 | 10:46 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
My Vortecs are milled .020 and im running a head gasket thats .015 compressed with no problems. Hod rod had their Vortecs milled .040 with no problems using the same head gasket, with a cam that was about .480 lift if I remember, so you should be ok with .040.
Magman
Sep 12, 2015 10:43 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
