how to make ram air functional
Old Nov 2, 2002 | 09:06 PM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
hey i just put on a ram air hood. is there any way to make it functional with a tbi? i already have a open element.thanx
Old Nov 3, 2002 | 01:37 AM
JPrevost's Avatar
Car: 91 Red Sled
Seal it off from the engine bay and that would do it. Just remember that when it rains you don't want water running down and filling your motor up!!! Yes I've seen a few setups that have done this, don't ask, don't tell, just use it as a warning to drill small drain holes for the water.
As for the design, just understand that most "ram air" hoods don't function like ram air. Usually their vents are too low against the body lines and air is more likely to flow over than under and in. This case can be observed with pro drag cars and the snorkels that lift off the hoods.
What hood do you have?
Old Nov 3, 2002 | 05:24 PM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
ascd ram air hood
9192camaro
16
Feb 3, 2019 12:21 AM
kyle5647
Aug 15, 2015 11:56 PM
L98GTA87
Aug 11, 2015 06:55 PM
mustangman65_79
Aug 11, 2015 03:17 PM
bryan623
Aug 10, 2015 11:33 AM
