Q-jet to TBI
Old Nov 3, 2002 | 10:43 AM
pandorafowler's Avatar
Car: `91 rs
Engine: 352 TPI
Transmission: TH700 R4
Q-jet to TBI
I just bought a 86 Z28 with a Q-jet yesterday. would it be best to replace it with the tbi setup from my wrecked 88 or just get it rebuilt( the Qjet)? I don`t know much about the Q-jets so for ease of maintanence would it be best to swap to tbi
Old Nov 3, 2002 | 11:36 AM
NJ SPEEDER's Avatar
electronic controls will net more power, mileage, and drivability than mechanical controls of the q-jet. i do know some people that have goten q-jets to run pretty good, but everyuone i kow that has switched to soem form of fuel injectioon has picked up noticably from the swap.
later
tim
Old Nov 4, 2002 | 06:15 PM
Car: `91 rs
Engine: 352 TPI
do i need to switch to a intank fuel pump or get a aftermarket electric pump to use the tbi system?
Old Nov 4, 2002 | 06:55 PM
NJ SPEEDER's Avatar
you will want a fuel pump that can support 10-12 psi. an intank set up would be nice, but if you are on a budget you may be able to get away with using a block mount style high volume pump. you will just have to run a return line. or you can switch to a mallory or similar electric pump. teh advantage of teh intank is that it is much quiter than external electrics, i don't know how important that is to you, i find th atconstant humm very annoying, maybe you don't.
later
tim
Old Nov 9, 2002 | 04:37 PM
Car: `91 rs
Engine: 352 TPI
Do I need to swap out the computer for the tbi setup or will the qjet computer work? Also how hard is it to change the wiring harness or would i be able to use the same harness?
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
