more problems
Old Nov 5, 2002 | 08:04 PM
bandit45's Avatar
more problems
Alright I finally got my car running so I threw on the valve cover n they were the usual pita to get on. I had my dad help me and he beat up the wiring harness a bit in the process. My tps is just connected by wires twisted together but it ran with it before and they are still connected. Now after puting on the covers I tried to start the car and its turns but the injectors arnt giving any gas. So whats my problem?? I'm so frustrated i would really apreciate it if someone could help.
Old Nov 5, 2002 | 10:27 PM
TBI305Camaro's Avatar
make sure the ignition module is hooked up and good.
Old Nov 7, 2002 | 08:59 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
I don't know if you were doing any work on the fan, but the fuel pump relay is wired right where the fan is wired as well. When I was messing around with my fan, I accidentally unhooked the fuel pump as well. The hookup is right next to the battery. Check to see if the fuse for the fuel pump is fine and if the pump makes noise. If that doesn't work, check for pressure at the injectors to see if there is an obstruction in the fuel line. The fuel lines run right next to the valve covers so you may have screwed something up there.
Good luck
Old Nov 7, 2002 | 04:27 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
Check the fuses fot the injectors. They each have their own fuse. If you have frayed wires they may have shorted on something and blown.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
