tps is reading 2.1 at idle
Old Nov 15, 2002 | 07:52 PM
CHEVYTOWN's Avatar
Does this mean this is helping to the average reading of 108 for the BLM's? What should the tps be reading at idle? I'm using WinALDL for the scanning tool. Ctown
Old Nov 15, 2002 | 07:57 PM
NJ SPEEDER's Avatar
the stock setting for the tps is supposed to be .50 or as close as you can resonably get it. that is stock, you can move it around to help with throttle response.
later
tim
Old Nov 15, 2002 | 08:05 PM
CHEVYTOWN's Avatar
Thanks NJ. I'm not sure if it's stock, probably not. When I purchased the kit from Howell, I told them the L6 was moderately modified. I know I had to adjust the throttle stop screw. I jumped the aldl with a paper clip and followed the steps. However, I couldn't adjust it while the engine was on like Howell told me to. It reved like mad without the IAC connected. So I adjusted it while the engine was off. It idles around 700-750. Thanks again hometown...
specialized
Jun 18, 2022 09:26 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Regal105
Aug 23, 2015 03:45 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
