What is that ?? pic
Old Nov 24, 2002 | 08:54 AM
PatrickRSpl's Avatar
Car: Camaro
Transmission: th700r4
What is that ?? pic
Old Nov 24, 2002 | 09:00 AM
Car: Camaro
Old Nov 24, 2002 | 09:12 AM
Slade1's Avatar
It looks like its connected to the coolant temperature sensor...
There are 3 places you can read the temperature from, the intake manifold like there(where the ecm gets its reading), the drivers side between cylinder 1 & 3(where the dash gets its reading) and finally the passenger side(where the fan switch gets its reading).
I guess someone decided that it would be good to get the reading from the intake since that's the same one the ecm is reading.
Old Nov 24, 2002 | 04:07 PM
Car: Camaro
Evertthing works great ( gauge , fan )
What You see , it looks like home made work ? I saw few tbi engines and nobody have something like this. I want back to factory setup . How to do it ?
Old Nov 24, 2002 | 05:30 PM
Slade1's Avatar
First figure out what those 2 extra wires are connected to before you go re-arranging that setup.
Normally there is a 2 wire connector leading to the wiring harness which is the ECM's temperature sensor.
The smaller brass connector should be able to be removed and then connected directly to the manifold instead of the large "thing".
Next is to figure out where those other connectors go as the dash guage is connected to a single wire temperature sensor on the driver's side head.
Old Dec 2, 2002 | 10:08 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Mmm, Slade:
My 2.8 V6 has two coolant temperature sensors: One (big) in the intake manifold; the other (small) in the head.
I did some tests and the reading were different between the dash and the scanner (dash was bigger than the scanner). What is the right reading or temperature signal in order to protect the engine for overheating?.
Thanks in advance for the reply,
Denis V.
Old Dec 4, 2002 | 09:14 AM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
Re: What is that ?? pic
Originally posted by PatrickRSpl
PatrickRSpl-
It doesnt look bad at all. Kinda reminds me of the saying "If it ain't broke, dont try to fix it".
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TexasFormula
Sep 30, 2015 06:36 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
