I6-250 carb -> TBI
Old Dec 2, 2002 | 11:33 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
I6-250 carb -> TBI
No, this isn't for me.
I was brainstorming this conversion and it occured to me that the best choice (for sticking with GM TBI) would be to use the 7747 ECM out of a fullsize C/K that originally had a 4.3L V6 installed.
The installation is in an 83 Chevy C10 w/ a 250 I6 and this EFI setup may have to eventually bolt up to a 292 (I6). One of the problems that I thought of was knock sensor compatibility. I realize the simplest approach is to disable that part of the ECM through EPROM burning but I think a knock sensor circuit is a nice thing to have. What type of knock sensor would work with a 250 or 292?
Also, how would we work in a GM HEI setup? I'd imagine some machining may be in order, but that's not a problem.
I have no idea what the cam selection would be, but I can probably guess mild. Does anybody have any input on this project?
Old Dec 3, 2002 | 07:18 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
There are several people on the www.diy-efi.org that have done that very swap. You can modify the distributor to run the electronic stuff and they use the knock sensor in the engine.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
