NEEd help asap
Old Dec 9, 2002 | 09:15 PM
jdrafke's Avatar
NEEd help asap
hi, tryin to install open air element 14x3 cant fit under 2" hood need help. can i remove anything to do this?
Old Dec 9, 2002 | 09:45 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It should fit without any problems. Make sure that you aren't running into the distributor cap. That was my problem until I added a half inch spacer to clear it. I have the drop base (I think) that sits a little lower than the TBI unit. It is the more restrictive of the two you can get. I still use the gold spacer around the TBI.
Old Dec 10, 2002 | 12:02 AM
deadtrend1's Avatar
Are you using a drop or a non-drop base. If you using non-drop, did you remember to pull off the space ring? That might be holding you up.
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
