Cam selection w/ stock chip?
Old Dec 12, 2002 | 08:42 PM
raggedout91RS's Avatar
Car: '84 Z28
Engine: Goodwrench 350
Axle/Gears: good guess
I'm looking to do a cam swap in my 91RS. I want a decent powerband that runs to 5000-5500 RPM.I will be running a 4barrell dual plane w/ tbi adapter and slightly ported 416's and will probably step up to 3.42 gears. The cam will have to work w/ stock chip cuz I'm just not ready to pull my hair out and go broke trying to learn how to burn chips. The cam doesnt have to be roller cuz I have a low mileage 305 non-roller that I am thinking of swapping in, not sure yet. Any opinions or advice would be greatly appreciated.:lala:
Old Dec 13, 2002 | 08:28 AM
deadtrend1's Avatar
I'd go LT1 cam if you dont wanna do eprom tuning. Stay away from there edelbrock and crane cams that say "Will work with existing ECM" or whatnot.
Old Dec 13, 2002 | 08:38 AM
JPrevost's Avatar
Car: 91 Red Sled
lol, go broke burning your eproms, HAHAHAHA, yeah right. $200 for all the good stuff, $140 for the minimal compared to $1000+ aftermarket systems, hmmm.....
Any cam mild enough will be computer friendly. It won't run at it's potential but it will run well enough that you won't have idle troubles. Just keep the duration low and the lobe sep higher than 112. The lift isn't as much a factor but even that can effect the vacuum signal. Stock eprom, lt1 cam is the biggest I'd go if I didn't burn my own eproms. If you did burn your own you could easily squeeze an XE268 cam in with little difficulty.
Old Dec 13, 2002 | 07:20 PM
Car: '84 Z28
Well, I'm on somewhat of a budget and I've priced all of the equipment and it came out more than $200, but that is the easy part. I'm not that comp. literate and I think I would have a hard time with it but I would be willing to try if I knew I wasn't throwing my money away.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Zell1luk
Sep 29, 2015 10:36 AM
