Tach bouncing all over under constant throttle
Old Dec 16, 2002 | 08:32 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I went to change my timing today and took it from 11 to 8, but afterwards I drove it and instead of a smooth acceleration, the tach bounces from like 1.5k to 2, then back down to 1.75ish, then back up to 2.25, etc etc... fuel pressure stayed the same.
I disconnected the computer advance when I set the timing, and its connected now. I put the timing back to 11 and its still going nuts just the same.
Any suggestions please?
Old Dec 16, 2002 | 08:41 PM
JR305's Avatar
Does it only happen when the car is warm? Does the car jerk with the tack?
I had a problem similar to this it ended up being a loose wire. I would go back and look behind the distributor for anything you may have knocked loose.
Old Dec 16, 2002 | 08:50 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Yea, the car bounces all over with the tach. Ive ran it when it was cold and when it was warm, no difference
Heh, just when you think you got the problems ironed out... ah the joys of building a car...
Old Dec 17, 2002 | 01:47 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Plug wire on #5 cylinder fell off!
Running like a champ though
Old Dec 17, 2002 | 02:38 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i hate it when that happens
IROCtometal
Sep 20, 2015 11:08 PM
TrevinE
Sep 14, 2015 03:20 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
