broken TBI injector terminal
while reinstalling my air filter, i broke the clips on one of the electrical terminals that hold it to the top of the injector. looking at the wiring, i don't see an easy way to replace it w/out cutting & splicing somewhere. is this right? anyone know how much that part is? (i assume GM only...) thank goodness for zip ties!
Car: check
Engine: check
Transmission: check
Re: broken TBI injector terminal
Now for the fix: get a decent junkyard connector set and swap just the housing. The terminals are easily removable from the housing. I don't have one here but if you look at one there is a cover that flips over and clips into place where the wires exit the housing. Unclip this first.
Then I believe there is a barb on the actual connector terminal. Press that in and the terminal will slide out of the housing.
RBob.
P.S. just watch out for the ones that have caught fire and have melted! Vans & Astro vans also use the TBI.
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
I break them all the time myself . they are easy to replace. bone yard it
