where's your timing, and getting at the hold down???
Old Dec 26, 2002 | 10:13 PM
trace's Avatar
car was acting funny, so i checked the timing. on the emissions label, it calls for 0º TDC. mine's around 10º BTDC at idle. where's yours? i was thinking 8º BTDC would be a good starting point, so...
i was going to adjust it, but how the frick do you get the dist hold-down bolt loose? i can't get a socket on it using an extension and u-joint, and can't get a box wrench down in there either... >:-|
FWIW, that wasn't the problem. the wires came loose from one of the injectors. (see other post)
TIA~Trace
Old Dec 26, 2002 | 10:17 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
ha ha....that little bolt can be a bit of a stubborn one unless you have the proper wrench, a couple of months ago I finally broke down and went out and got one, they are ususally available from any parts/tool place.
Old Dec 27, 2002 | 12:10 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I got a cool little socket that looks like an open end wrench and just put a nice long extension on it. Worked great with the stock manifold!
Old Dec 27, 2002 | 12:19 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
A crowfoot should work.
Old Dec 27, 2002 | 07:14 AM
trace's Avatar
ah! crow foot, didn't even think of that. i've been needing a set anyway, sounds like a good excuse to buy.
so what about the timing setting?
thanks.
Old Dec 27, 2002 | 08:10 AM
super chevy's Avatar
Mine seems to respond best with timing set at 2 degrees BTDC.
SC
Old Dec 31, 2002 | 08:13 AM
Jza's Avatar
Jza
I also got good results at 2° or 3°. But I set it to 0° for a trip and got about 4mpg better than I usually do on the highway so I've left it that way since.. hehe.
Old Dec 31, 2002 | 05:02 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
if its near stock then 10 will be too much for one of the later cars. Youll probably get a flaky idle and detonation with too much base time. i dont even know what mine is. Its so far of the pointer that i cant tell... maybe 25 deg btdc? Oh... ive also found that an old boxend wrench cut in half works quite well to lossen and tighten the bolt.
Old Jan 2, 2003 | 08:08 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Make sure that 10 degrees is with the tan/black wire disconnected. A lot of people run 6-8 degrees advanced on here.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Clean87TA
Sep 4, 2015 11:23 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
djmarch
Aug 9, 2015 05:27 PM
