Do I need to increase the fuel pressure?
Old Jan 10, 2003 | 10:55 AM
BowtieFever's Avatar
I just installed headers, y-pipe, new cap, rotor, sparkplugs, wires, & oxygen sensor. My other mods are in the sig. Anyway, my fp setting is at the lowest. I know that the LO3's normally run rich from the factory. Is it reasonable enough, to now increase the fuel pressure alittle?
Old Jan 10, 2003 | 12:35 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Its at the lowest? If thats the case you're only running like 7 psi of pressure! Stock setting is near the middle, at least on mine it was dead middle. With your mods I'd put it just a little above stock. Get WinALDL if you can to find out what your o2 sensor is reading then adjust from there.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
