Are TBI and TPI distributors the same?!
Old Jan 10, 2003 | 10:06 PM
MILT's Avatar
I need to know if a TBI distributor will work with a MAF TPI setup or vice-versa.
Thanks,
MILT
Old Jan 11, 2003 | 07:35 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I believe the TPI distributors are smaller so they fit behind the plenum but I could be wrong.
Old Jan 11, 2003 | 12:17 PM
vjo90RS8's Avatar
Car: 2002 Z28
I think that TPI engines got distributors with an in-cap coil, but other than that i believe the rest of the distributor is the same as the one in our cars.
Old Jan 11, 2003 | 12:37 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
My 89 TPI came factory with a external coil..
Old Jan 11, 2003 | 04:51 PM
vwdave's Avatar
The early ones had the coil on top, later ones had external.
Old Jan 11, 2003 | 06:07 PM
NJ SPEEDER's Avatar
tbi and tpi both use teh same small cap, divorced coil hei distributors.
later
tim
Old Jan 19, 2003 | 10:49 AM
Pat Hall's Avatar
Man! Sure is a lot of confusion on that issue! It's just as Tim put it, they're all the same from around '87 on up.
pimp2303
Jul 27, 2017 02:03 PM
Caspar
Jun 19, 2016 11:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
tero
Aug 6, 2015 06:34 PM
