goofy oil gage is gonna give me a heart attack
Old Feb 17, 2003 | 09:48 AM
rsc350's Avatar
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
Ok here it is, I get in my car start it, oil guage is at 80 no matter what untill the car warms up, always been like that and still is, but now when the car warms up the oil pressure goes all the way down to real close to 0, where as at idle it used to sit at 40. As soon as I take off from idle the oil gauge reads same as it always has, which has always been high, manley high flow oil pump, valvoline durablend oil, mobil 1 oil filter, 17* outside. I took off the oil cap and checked the flow on the drivers side head, looks like it did when it was new. That guage just flips me out and gets me worried, what elce should i check or what tests can i do to be sure that my oil preuusre aint really that low?? Thanks in advance for the help.
Old Feb 17, 2003 | 09:59 AM
CrispyClutch's Avatar
Eh I wouldnt worry about ot,you should see my gauge...it ticks back and forth like you wouldnt believe.
Old Feb 17, 2003 | 10:54 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Something I've learned about our gauges. . .
Oil pressure = crap
Gas level = crap
Tach = crap
Water temp = too accurate, freaks me out.
Trust me, you'll know it when your oil pressure is below 20 psi. Your engine will sound like a washing machine.
-The Gunny
Old Feb 17, 2003 | 11:14 AM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
what if we install some autometer gagues would those be all right. and i dont want the mecanical gauge's either
Old Feb 17, 2003 | 06:15 PM
v8unleashed's Avatar
i'd replace the pressure sending unit first
and of course, mine guage doesnt work either...........
Old Feb 18, 2003 | 07:21 AM
JeffC1500TBI's Avatar
mine worries me as well.. when I first start it up it takes a second before it decides to kick all the way up to 3/4.. just that second it sits at 0 is what scares me..
Old Feb 19, 2003 | 06:20 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
If you want real peace of mind, add a mechanical oil pressure and water temp gauge. I did.
Even with a new sender sometimes a ground problem will give you a flaky reading on any electrical gauge.
A mechanical will work even if there is no electrical power.
-Rich-
Old Feb 23, 2003 | 07:10 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
if it had too much oil pressure or too little oil pressure you would have heard it by now
more then likely the gauge has kicked the bucket the one in my RS is dead
maroe624
Apr 16, 2017 08:29 AM
BewleyBizzIROC
Sep 7, 2015 08:05 PM
Navy8125
Aug 21, 2015 09:32 AM
Irocohio
Aug 12, 2015 08:03 AM
