Bored Out 454 TB
Old Feb 25, 2003 | 08:03 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Bored Out 454 TB
I haven't had time to read all the related threads, but I'm gonna throw this out anyway.
I hear mention of using 454 TB's. I'm a member of the NATC, which is dedicated to the 90-93 BB trucks. We have a member that bores and sleeves 454 TB's. The bore size is 56 mm and the throttle shaft is reduced to 4.8 mm. Go to www.454ss.com and look in the gallery section. Check out Jim Dickie's section. He gives a detailed explanation of this mod.
I am currently using one of these TB's on my truck and it is awesome! Jim can also modify intakes/adapters/spacers to use with the modified TB. Contact Jim for pricing.
I've also heard mentioned of higher flow injectors, but none of our members have been able to source any. Where are you getting these?
Bill
Old Feb 25, 2003 | 12:13 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Bored Out 454 TB
Bill
Wow, I'll bet the 56mm bores help out. My only question is what is used to funnel the bore width to the manifold? (I'll hit the web site next). I've had trouble getting a 52mm bore on the square form 4bbl manifold.
As for injectors the largest I know of are 90pph. Bumping the fuel pressure to 16-20psi will net a bit more flow.
My understanding is that there are larger injectors then these. They are for export vehicles running alcohol. I have not yet been able to verify this.
RBob.
Old Feb 25, 2003 | 02:49 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I went there and searched all around and didn't find anything about a bored out TBI, or Jim Dickie, or anything of the sort
Old Feb 25, 2003 | 02:55 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
go here... bb tbi
Old Feb 25, 2003 | 02:58 PM
Car: 88 Camaro SC
Engine: SFI'd 350
man that thing is dope... It lookes like it would be a pita top get it to fit under the stock hood with a carb to tbi adapter, though... i want one. Shame it cant be used easily with the fuel injectors.
Old Feb 25, 2003 | 04:00 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Originally posted by dimented24x7
go here... bb tbi
I must be blind. Thanks...note to self: do not surf the net at 8 am
With the MPFI on there why didn't the guy just buy a 4 bbl TB from Holley? He would've saved money and got 200 more cfm...
Old Feb 25, 2003 | 06:29 PM
steve8586iroc's Avatar
I'd like to see how much he spent on those heads.
Steve
Old Feb 25, 2003 | 06:37 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Steve
Over $2K.
Old Feb 25, 2003 | 06:41 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
It can be used with stock injectors. In Jim's application, he has the velocity stacks installed because he has multipoint injection. I have one of his modified TB's and am using the stock injectors, FPR, etc.
Bill
Old Feb 25, 2003 | 06:51 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Re: Re: Bored Out 454 TB
RBob.
I am currently using the Edel TB manifold with a 1" phenolic spacer. Both of these have been bored out to match the TB.
I am switching over the RPM Air Gap as soon as I get my heads finished. The TB will be mated to the intake with the Holley adapter (also bored out).
Bill
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
hartsmike
Oct 2, 2015 07:11 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
