Holley 670 vs 350 injectors
Old Feb 27, 2003 | 08:27 PM
vwdave's Avatar
I am swapping a 350 from a L98 into my 89 RS. I have a LT4 cam in it, headers, exhaust, and a K&N. Should the 350 truck's Throttle body and injectors be enough to feed it?
I want to swap to tuned port in the close future, but I need my car done.
Old Feb 27, 2003 | 09:23 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I'm doing basically the same swap as you in my car. I plan on going with the 65# injectors from the caprice 9C1's because they had basically an L98 with TBI from the factory, so that would be your closest match. Then you can get the ANLU prom from that 9C1 and that's a good base to program off of. The truck injectors are 55pph by the way, so they'd probably work too I'd assume but 65pph would be the best way to go I think.
Old Feb 27, 2003 | 09:25 PM
vwdave's Avatar
Thats.....a good damn Idea.
Does it retain the VATS too? I know the trucks dont.
Old Feb 27, 2003 | 10:02 PM
BronYrAur's Avatar
Engine: 305 TBI
No, it doesn't retain the VATS as far as I know, but if you can get a hold of some prom burning equipment you can re-enable it I believe or possibly you could send your chip to some of the hot shot prom burners on this board and they could re-enable it for you, I was actually trying to think about the same thing because I would like to retain the VATS.
Old Feb 28, 2003 | 05:56 PM
vwdave's Avatar
I found the stuff I needed and it is arriving Tuesday.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
theurge
Aug 21, 2015 12:46 PM
