lo5 heads
Old Mar 2, 2003 | 02:53 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
lo5 heads
i have a rebuilt LO5 and would like to know the specs on these heads. also what would be a good upgrade. mods are in sig. 1.6 roller rockers will be goin in with heads.
Old Mar 2, 2003 | 08:43 AM
steve8586iroc's Avatar
Are you looking for combustion chamber size like 72 to 74 cc's, valve sizes like 1.94in. and 1.50ex., as far as flow numbers I'd say there not very good but you could check out the head flow test here http://www.chevyhiperformance.com/te...598/index.html at the bottom of the page click on catagory 2 maybe you'll find what your looking for there.
Steve
Old Mar 2, 2003 | 09:31 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
im looking for a head that will give me more power. and that could support the lift created by my cam with 1.6 rollers.
Old Mar 2, 2003 | 09:45 AM
It really depends on how much you have or want to spend, and how much work you can do yourself.
Steve
Old Mar 2, 2003 | 01:09 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
im a mechanic and ill probably spend $1000 total for heads and rockers
Old Mar 2, 2003 | 02:13 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Well, I don't know the specs on the lo5 heads but I know they're swirl port heads just like the lo3 heads and flow terribly, so if you want to make some real power and have 1k bucks to spend on heads I'd say ditch the lo5's as quick as you can. I'm not to big into the performance heads and what's the best for your money but I'm sure other guys will chime in on that. I know that AFR heads are recognized as some of the best, you might want to look at some of them and I know that Pro Lightnings are kind of a hot head to get lately on the boards, might want to check them out too, just some ideas.
Old Mar 2, 2003 | 03:16 PM
Here's a set of Vortecs ready to bolt on and add your 1.6/1 rockers to. http://www.paceparts.com/product.asp?0=0&1=0&3=55999
You should be able to do it for less than a grand depending on the rocker arms you select.
Steve
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
